[Qgis-developer] QgsGeometry, Geos and SFCGAL
Sebastiaan Couwenberg sebastic at xs4all.nl
Sat Mar 11 15:07:21 PST 2017
On 03/11/2017 04:26 AM, Nyall Dawson wrote:
> Instead, a better approach is if we selectively change certain
> operations to use a different backend only after we carefully evaluate
> the results for each individual operation concerned. E.g. if we found
> that SFCGAL resulted in intersections which are equally reliable as
> GEOS, and faster in the majority of geometries, then we'd change
> QgsGeometry::intersection to ALWAYS use SFCGAL.
SFCGAL is not very actively developed, in its current shape is not the
best choice to build upon. It either needs more active participation
from the community, or better funding. Since the initial funding dried
up, the activity in the project slowed to a crawl.
I'm considering removing the SFCGAL support in the PostGIS Debian
package if the situation doesn't improve. For the same reasons I'd be
reluctant to enable its support in QGIS if that were to arrive.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
