[Qgis-developer] R in Processing: errors not shown
matteo matteo.ghetta at gmail.com
Mon Mar 13 07:17:25 PDT 2017
> this did not happen in my case
ok, not sure if this is related to this mandatory R packages
> after installing them, the error is gone, and the entries appear on the list
ok, do you have ggplot2 installed? If not, try to import the attached
script (copy and paste the content in the editor) and try to use it
if it works and you did not had ggplot2 installed then Processing is
able to install additional packages, if not, then I'm totally wrong :)
Matteo
##[R-Geostatistics]=group
##showplots
##Layer=vector
##X=Field Layer
##Group=optional Field Layer
#Log_Scale = boolean False
##Data_Transformation=selection normal;log10;ln;sqrt;exp
require(ggplot2)
if(Data_Transformation == 0){
ax <- scale_y_continuous()
yy <- ylab(X)
} else if(Data_Transformation == 1){
ax <- scale_y_log10()
yy <- ylab(paste("log10", X))
} else if(Data_Transformation == 2){
ax <- coord_trans(y = "log")
yy <- ylab(paste("ln", X))
} else if(Data_Transformation == 3){
ax <- coord_trans(y = "sqrt")
yy <- ylab(paste("sqrt", X))
} else if(Data_Transformation == 4){
ax <- coord_trans(y = "exp")
yy <- ylab(paste("exp", X))
if(is.null(Group)){
ggplot()+
geom_boxplot(aes(x=1, y=Layer[[X]]))+
xlab("")+
yy +
ax +
ggtitle(paste("Boxplot of", X))
} else {
ggplot()+
geom_boxplot(aes(x=Layer[[Group]], y=Layer[[X]], fill=as.factor(Layer[[Group]])))+
xlab(Group)+
yy +
scale_fill_discrete(name=Group) +
ax +
