[Qgis-developer] Future of spatialite provider?
Andreas Neumann a.neumann at carto.net
Mon Mar 13 13:25:54 PDT 2017
Hi Josef,
 From http://www.gdal.org/drv_geopackage.html
"The core GeoPackage specification does not currently support
non-spatial tables, but starting with GDAL 2.0, the driver allows
creating and reading such tables via the Aspatial Support
(gdal_aspatial) extension. Note: starting with GDAL 2.2, the driver will
also, by default, list non spatial tables that are not registered
through the gdal_aspatial extension."
So with newer GDAL versions it is possible to create and read
non-spatial tables.
Andreas
On 13.03.2017 17:13, josef k wrote:
> Here is just a reminder from a user/plugin maintainer, please ignore
> if not relevant.
> If the spatialite data provider is to be removed then we will have to
> update some plugins to reflect that which is ok, not a big deal. But
> it is important that the current features of the spatialite data
> provider are included into the OGR provider before changing.
> E.g. we are using the spatalite data provider in plugins to add
> non-spatial spatialite tables. I could not achieve this by using the
> OGR provider (although it was a couple of years ago I was looking into
> this and it may have changed by now).
> regards
> Josef
>     On Mon, 13 Mar 2017 11:28:45 +1000, Nyall Dawson wrote:
>         I'm wondering what the future of the spatialite provider
>         should be. I
>         find it odd that spatialite layers utilise the dedicated
>         spatialite
>         provider, but geopackage layers use the OGR provider.
>         I think there's potential value in removing the spatialite
>         provider
>         and always reading these layers via OGR.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170313/bdab2e25/attachment.html>
