[Qgis-developer] Corrections of QgsOgrProvider implementaion of GDAL 2.0
Nyall Dawson nyall.dawson at gmail.com
Mon Mar 20 16:32:30 PDT 2017
On 21 March 2017 at 09:23, Mark Johnson <mj10777 at googlemail.com> wrote:
>> Yet I still see lots of code in that PR like:
>> if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >=
>> GDAL_COMPUTE_VERSION(2,0,0)
>> That's what I'm referring to. All this conditional code needs removal
>> (unless it's testing for something in GDAL > 2.0 ).
> Mosty in the static functions
> - QgsOgrProviderUtils, mostly with a switch
> and a few elsewhere.
> There are also few for much older versions
> #if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1400
> They are easy to remove.
> There is one (at least) that must remain
> #if defined(GDAL_COMPUTE_VERSION) && GDAL_VERSION_NUM >=
> GDAL_COMPUTE_VERSION(2,1,2)
> I count 20, beforehand there were many more.
> There also other classes sped around the project that uses OGR
> - some of which also have these
Ok - I find this thread very confusing. Does this acknowledgement mean
that you WILL remove these ifdefs from the PR?
Here's the thing: I *want* your work to land in QGIS. It's important
stuff, and needs to be addressed. But in its current form it won't be
merged - it's been independently reviewed by two core developers who
have both requested changes. I hate to see all this effort you've put
in wasted, but you need to rework your approach before this can be
merged.
Nyall
