[Qgis-developer] Adding default OSM backround maps
Tom Chadwin tom.chadwin at nnpa.org.uk
Wed Mar 22 07:27:23 PDT 2017
Greg Troxel-2 wrote
> According to the policy, QGIS would probably need permission to offer
> tiles from OSM servers.
That is what Paolo has been discussing with OSM.
Greg Troxel-2 wrote
> I'm unclear if this discussion is only about using OSM as a base layer
> within QGIS, or also extends to publishing created maps on the web such
> that web users would load tiles.  Generally, OSM tileservers are
> intended to support OSM itself, and for low-usage applications.  So it
> might be that for publishing it would be good to ask people to check
> that they've read the tile usage policy.
It would be a fully-featured layer within QGIS, which users could publish.
Greg Troxel-2 wrote
> Socially, if you have a facility to add OSM, then by default, adequate
> attribution should be added, so that someone who does not understand how
> to set up attribution or does not understand that they must will end up
> doing thte right thing.
Yes, we would add the approved attribution by default.
Tom
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-default-OSM-backround-maps-tp5313358p5313657.html
Sent from the QGIS - Developer mailing list archive at Nabble.com.
