[Qgis-developer] QGIS crashes when zzoming in
Matthias Kuhn matthias at opengis.ch
Thu Mar 23 08:39:21 PDT 2017
Hi Paolo,
a backtrace would still help a LOT more. Can you provide one?
Matthias
On 03/23/2017 04:26 PM, Paolo Cavallini wrote:
> Il 23/03/2017 14:57, Matthias Kuhn ha scritto:
>> Hey Paolo,
>> Any chance to get a backtrace?
>> This is always the number one resource for pointers to solutions with
>> crashes.
> OK, so I found that the crash depends on a single PostGIS point layer in
> EPSG:4326. When the project is reprojected to EPSG:3857, QGIS reliably
> crashes when zoomed deeper than 1:50.000.
> When OTF is off, no issue. Same layer, saved as shp in the same
> situation does not crash. I suspect this has to do to the incorrect
> extent of the geom:
> Extent:
> -inf, -inf - -10.56548, 9.94114
> I understand why QGIS has trouble in reprojecting it, but a crash is
> always bad.
> BTW: how do I fix the extent of the PostGIS table?
> All the best.
