[Qgis-developer] Plugin upload required fields
Matthias Kuhn matthias at opengis.ch
Sun Mar 26 09:29:14 PDT 2017
Hi Alessandro,
It didn't appear for more than 48 hours in the repository (for QGIS
master) with this file here:
https://github.com/opengisch/projectgenerator/blob/c23b3764704bcd0a73bf44f6a46c5d256f251dd9/projectgenerator/metadata.txt
It works now with this file here:
https://github.com/opengisch/projectgenerator/blob/b2e7f92a4dd6f21c12bceaafea36d496c9e3bbe4/projectgenerator/metadata.txt
The line-endings where also changed at some point (dos-endings with CRLF
to unix endings).
Matthias
On 03/26/2017 06:23 PM, Alessandro Pasotti wrote:
> Hi Matthias
> I'm not sure what you mean by
> 3.0 repo, but if it is the official repo both fields are optional
> according to
> http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html#plugin-metadata
> <http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html#plugin-metadata>
> Keep in mind that the xmls are cached and regenerated every 30 minutes.
> If you still find an issue with that metadata please file a ticket and
> attach the plugin.
> Cheers
> On 26 Mar 2017 4:03 p.m., "Matthias Kuhn" <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi all,
>     I uploaded a new plugin to the 3.0 repository some days ago and it
>     wouldn't show up in the plugin list. I first suspected something related
>     to min/max version but it turned out, that I had to add (at least one
>     of) the keys experimental and deprecated to make it be listed.
>     I remember that I was first asked to fill in some required fields at
>     some point (tracker, repository...) I wonder if these fields should also
>     go in there - or if they should really be made optional.
>     Thanks
>     Matthias
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
