[Qgis-developer] QGIS X3D processing
Andreas Plesch andreasplesch at gmail.com
Mon Mar 27 05:49:33 PDT 2017
Let me share a project for interactive 3d visualization of qgis content on
the web using the geospatial component of the standardized X3D format. Code
and examples are on GitHub:
https://github.com/andreasplesch/QGIS-X3D-Processing
This effort is similar to QGIS2Threejs but is just starting out and
will use quite a different approach.
On the user list Paolo mentioned plans to use native qt5 3d facilities for
qgis3 as well (see below). Is there a repository or documentation to learn
more about this ? For example, it may be beneficial to use webGL enabled
webkit (perhaps in the processing results viewer).
Any pointer or other feedback is very welcome,
Andreas
Date: Mon, 27 Mar 2017 08:15:36 +0200
To: qgis-user at lists.osgeo.org, qgis-developer
        <qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS X3D processing
Message-ID: <6dab7995-95d0-21c6-c8b3-347f18ade72f at faunalia.it>
Content-Type: text/plain; charset=utf-8
Il 27/03/2017 01:52, Andreas Plesch ha scritto:
> Hi Paolo,
>     Date: Sun, 26 Mar 2017 20:22:06 +0200
>     From: Paolo Cavallini <cavallini at faunalia.it
>     <mailto:cavallini at faunalia.it>>
>     Il 26/03/2017 00:27, Andreas Plesch ha scritto:
>     > I would like to share a project for 3d visualization of Qgis
>     content by
>     and will
>     > Any comment, feedback or thought is welcome,
>     Cool, thanks. AFAIK there are plans to use native Qt5 3D facilities,
>     have you had a look to this too?
> I looked into using qt webkit and found that qt5 webkit supports webgl
> (and probably a modern js engine?). That would be very interesting as it
> would be possible to rely just on webkit and perhaps have some tighter
> integration with the Qgis gui.
> What would be a good place to learn more about QGIS3 plans to use native
> Qt5 3d facilities ?
Hi Andreas,
I do not know much. You can probably have a look to the work of Minoru
Akagi, who started some early development on this.
However, I think some core devs may be interested in joining the discussion.
Andreas Plesch
39 Barbara Rd.
Waltham, MA 02453
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170327/dd0f331d/attachment.html>
