[Qgis-developer] Processing menu dropdowns
Neumann, Andreas a.neumann at carto.net
Thu Mar 30 01:33:35 PDT 2017
Hi Paolo,
While I agree with you that in most cases the same layer wouldn't be
chosen twice as input layers, I am not sure if your proposal is worth
the effort.
In >90% of the cases the user will have to change the input layer anyway
- so what is the gain?
Better to let the user consciously choose the correct parameters than
doing any wild guesses of what may be, by chance, the right choice in
some cases.
I think we have other, more pressing issues to fix besides this minor
issue.
Andreas
On 2017-03-30 09:36, Paolo Cavallini wrote:
> Hi all,
> in Processing, the interface prefills the dropdowns for the choice of
> input layers with the active layer. When >1 layer has to be chosen (e.g.
> for Difference) the same layer is selected twice. Of course Processing
> cannot know which other layer to select, but it's almost certain that
> nobody wants the same layer twice. I'd suggest therefore to put as a
> default the topmost layer, excluding the active one.
> Thanks.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170330/bd258a91/attachment.html>
