[Qgis-developer] automatic sip files generation
Alessandro Pasotti apasotti at gmail.com
Thu Mar 30 08:57:48 PDT 2017
On Thu, Mar 30, 2017 at 5:26 PM, Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Thu, Mar 30, 2017 at 5:02 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
>> Le jeu. 30 mars 2017 à 16:56, Tim Sutton <tim at kartoza.com> a écrit :
>>> Hi
>>> On 30 Mar 2017, at 3:18 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
>>> wrote:
>>> Dear all,
>>> I'd like to raise the attention on a new workflow I just merged to
>>> automatically generate SIP files using the header as source only.
>>> A PR is pending for the documentation, but you can read it here
>>> https://github.com/3nids/QGIS-Documentation/blob/6e3a9fb6f98
>>> a2869aef27c01b7ab70eb0a4c7556/source/docs/developers_guide/c
>>> odingstandards.rst#sip-bindings
>>> (waiting to be merged).
>>> For the moment, only 3 files are generated (qgsattributes, qgsfeature
>>> and qgsvectorlayer). One can starts adding new files to the process by
>>> adapting their header and removing them from python/auto_sip.blacklist.
>>> This is really great! A couple of questions:
>>> 1) the blacklist implies that any new .h files added to the source tree
>>> will automatically have sip bindings generated unless you explicitly
>>> blacklist them?
>> As soon as you add the include in python/core/core.sip (or gui,
>> analysis), the SIP is considered as automatically generated from header
>> except if you blacklist it.
>>> 2) are you thinking to maintain the sip files in Git still or remove the
>>> from revision in favour of having them as build time artifacts only? I ask
>>> this because I often direct people to use the sip files as a reference
>>> guide for the python API if they want to dig under the hood a bit more.
>> The goal is to remove the SIP files and have them created on build time.
> I surely missed something: how can you deal with annotations?
Oh, now I see the docs:
https://patch-diff.githubusercontent.com/raw/qgis/QGIS-Documentation/pull/1788.diff
Smart solution indeed!
Thanks!
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170330/43bb3459/attachment.html>
