[QGIS-Developer] [attributetable] #15803 "Sort on Top" regression or feature ?
Luigi Pirelli luipir at gmail.com
Wed May 10 01:24:15 PDT 2017
1) is already in the related PR
https://github.com/boundlessgeo/QGIS/commit/cae124acea62b3d387586e3c1619144a3c12b150,
btw more controls will be added on restrict SortOrder values.
2) hmmm... constructor start with the correct AscendingMode... someone
(a plugin or the core code or a bug) do
attributeTableConfig().sortOrder(<wrong value>). There are some wrong
set in ComposerAttributeTable, but I don't think it's the origin of
the problem
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 10 May 2017 at 08:53, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Luigi,
> Thanks for the detailed report. I think there are two different things to
> fix
> XML Loading: the static_cast should be accompanied by a validity check
> Fix the reason for 158 ever appearing (might just be a default value
> assigned to mSortOrder in qgsattributetableconfig.h)
> There's not much reason for flexibility here as far as I can tell, this just
> reflects the Qt::SortOrder enum. If required, we can add additional new
> flags for "SortOrderCaseSensitivity" and whatever might appear in the
> future.
> I hope that helps,
> Matthias
> On 5/9/17 11:24 AM, Luigi Pirelli wrote:
> Hi devs
> ***In short:
> The sortOrder value in QgsProject section:
> <attributetableconfig sortOrder="<some value>">
> can be any value for some reason (e.g. flexibility for the future) or
> it is a bug?
> I would ask to especially to Nyall that git blames is the author of
> this section:
> https://github.com/qgis/QGIS/blob/master/src/core/qgsattributetableconfig.cpp#L200
> ***Details:
> during hackmeeting I also worked on:
> https://issues.qgis.org/issues/15803
> in the team we had problem replicating the issue on QGIS 3.x so we
> discovered that the origin of the problem is in
> QgsAttributeTableConfig saved in Layer style section of the qgis
> project.
> here an example of a project I had with wrong values
>       <attributetableconfig actionWidgetStyle="dropDown"
> sortExpression="" sortOrder="158">
>         <columns>
>           <column width="-1" hidden="0" type="field" name="Cell"/>
>           <column width="-1" hidden="0" type="field" name="Time"/>
>           <column width="-1" hidden="0" type="field" name="Value"/>
>           <column width="-1" hidden="1" type="actions"/>
>         </columns>
>       </attributetableconfig>
> the value is casted to Qt:SortOrder enum with:
> that is undefined in case sortOrder value does not belong to the enum
> range, but in the implementation the value is leaved to 158 (as in the
> example)
> This generate some side effects in the attribute table => the
> sortOnTop button does not work because of:
> https://github.com/qgis/QGIS/blob/master/src/gui/attributetable/qgsattributetablefiltermodel.cpp#L53
> and
> https://github.com/qgis/QGIS/blob/master/src/gui/attributetable/qgsattributetablefiltermodel.cpp#L57
> that obviously returns always false
> The actual patch in:
> 2.18 - https://github.com/qgis/QGIS/pull/4306
> 3.x - https://github.com/qgis/QGIS/pull/4444
> protect the attribute table from having wrong sortOrder values, but
> does not try to fix it's value in AttributeTable config that can be a
> value set for some reason by the user or other components.
> ***Workaroud
> a simple workaround is apply a column sort and save the project to fix
> the wrong value
> Luigi Pirelli
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
