[QGIS-Developer] [Qgis-developer] [resolved] Qt4 asked when compiling current master
Raymond Nijssen r.nijssen at terglobo.nl
Mon May 15 05:55:34 PDT 2017
Thanks Pierre, I just ran into the same.
Should qt4-linguist-tools be added to the dependency list?
https://htmlpreview.github.io/?https://github.com/qgis/QGIS/blob/master/doc/INSTALL.html#toc6
Raymond
On 21-03-17 21:48, Pierre_Loicq wrote:
> Pierre_Loicq wrote
>> Hello,
>> I am trying to compile current master on ubuntu 16.04. I have this error:
>> [ 99%] Generating ../output/i18n/qgis_bg.qm
>> lrelease: could not exec '/usr/lib/i386-linux-gnu/qt4/bin/lrelease': No
>> such file or directory
>> i18n/CMakeFiles/translations.dir/build.make:97 : la recette pour la cible
>> « output/i18n/qgis_ar.qm » a échouée
>> make[2]: *** [output/i18n/qgis_ar.qm] Erreur 1
>> make[2]: *** Attente des tâches non terminées....
>> i18n/CMakeFiles/translations.dir/build.make:101 : la recette pour la cible
>> « output/i18n/qgis_bg.qm » a échouée
>> make[2]: *** [output/i18n/qgis_bg.qm] Erreur 1
>> CMakeFiles/Makefile2:3686 : la recette pour la cible
>> « i18n/CMakeFiles/translations.dir/all » a échouée
>> make[1]: *** [i18n/CMakeFiles/translations.dir/all] Erreur 2
>> make[1]: *** Attente des tâches non terminées....
>> [ 99%] Built target zzz-db_manager-5-depend
>> Makefile:160 : la recette pour la cible « all » a échouée
>> make: *** [all] Erreur 2
>> I don't know why Qt4 is asked here. ccmake configuration only talks about
>> Qt5
>> Thank you
>> Pierre
> Resolved ! I used apt-file to know which package I had to install:
> qt4-linguist-tools
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Qt4-asked-when-compiling-current-master-tp5310808p5313502.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
