[QGIS-Developer] PROPOSAL: change how we manage the 3.0 release process
Andreas Neumann
a.neumann at carto.net
Mon Nov 6 05:44:00 PST 2017
> Can you point me towards the issue reports with the information from the crash dialog?
I will try to report the crashes better. However, the crashes are often
not so easy to reproduce and not so easy to describe what I did. But
they happen quite often.
In general there are 22 open issues with crashes for master:
https://issues.qgis.org/projects/qgis/issues?utf8=%E2%9C%93&set_filter=1&f%5B%5D=tracker_id&op%5Btracker_id%5D=%3D&v%5Btracker_id%5D%5B%5D=1&f%5B%5D=cf_10&op%5Bcf_10%5D=%3D&v%5Bcf_10%5D%5B%5D=1&f%5B%5D=status_id&op%5Bstatus_id%5D=o&f%5B%5D=cf_9&op%5Bcf_9%5D=%3D&v%5Bcf_9%5D%5B%5D=master&f%5B%5D=&c%5B%5D=tracker&c%5B%5D=status&c%5B%5D=priority&c%5B%5D=subject&c%5B%5D=assigned_to&c%5B%5D=updated_on&c%5B%5D=category&c%5B%5D=cf_8&group_by=
and in addition there are 47 open issues with crashes on 2.18 - many of
them are also valid for master.
And the majority of QGIS users haven't really started testing QGIS 3. So
we should be prepared for many more issues.
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171106/0a9824a2/attachment-0001.html>
