[QGIS-Developer] Travis timeout
Alessandro Pasotti apasotti at gmail.com
Wed Nov 8 00:26:07 PST 2017
Hi Patrick,
to run python tests locally you can either use ctest from the build dir or
create a wrapper script that set paths and env vars before launching python
and the script.
Here is mine (you probably need to adapt it): http://dpaste.com/1C3FMZM
Recently Matthias also explained on this list how to run python tests
inside QtCreator.
Cheers
On Wed, Nov 8, 2017 at 9:22 AM, Patrick Valsecchi <
patrick.valsecchi at camptocamp.com> wrote:
> Hi,
> I'm trying to work on a feature in the master branch, but Travis constantly
> times out on my builds
> <https://travis-ci.org/pvalsecc/QGIS/jobs/297999069>.
> Did I miss something?
> Plus, I'm trying to run UTs on my machine, but the doc must be outdated.
> How do I run the tests in tests/src/python/test_qgsserver_wms.py locally?
> Thanks for your help
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171108/a4a5114a/attachment.html>
More information about the QGIS-Developer mailing list
