[QGIS-Developer] MetaSearch provider connections in master
Tom Kralidis
tomkralidis at gmail.com
Mon Nov 13 07:37:02 PST 2017
On Mon, Nov 13, 2017 at 10:32 AM, Alessandro Pasotti <apasotti at gmail.com> wrote:
> On Mon, Nov 13, 2017 at 4:24 PM, Tom Kralidis <tomkralidis at gmail.com> wrote:
>> On Mon, Nov 13, 2017 at 10:17 AM, Alessandro Pasotti <apasotti at gmail.com>
>> wrote:
>> > On Mon, Nov 13, 2017 at 3:59 PM, Tom Kralidis <tomkralidis at gmail.com>
>> > wrote:
>> >> On Mon, Nov 13, 2017 at 9:18 AM, Alessandro Pasotti
>> >> wrote:
>> >> > On Mon, Nov 13, 2017 at 3:06 PM, Tom Kralidis <tomkralidis at gmail.com>
>> >> > wrote:
>> >> >> Hi devs:
>> >> >> Given https://issues.qgis.org/issues/17347 I'm working on fixing
>> >> >> MetaSearch
>> >> >> provider connections in master. The core part of the code is
>> >> >> currently
>> >> >> at
>> >> >> [1]. A
>> >> >> standalone example can be found at [2]. Result is that the WMS/WMTS
>> >> >> provider
>> >> >> opens connecting to the selected WMS/WMTS (good). When clicking
>> >> >> 'Ok',
>> >> >> 'Close',
>> >> >> or 'Add', the WMS/WMTS layer is added (expecting 'Close' to simply
>> >> >> close the dialog
>> >> >> and 'Ok' to add the layer and then close). Finally clicking the 'X'
>> >> >> (top right) closes
>> >> >> the dialog as expected.
>> >> >> - are there other slots to call instead?
>> >> >> - should the Data Source Manager be used instead [3]? Are there
>> >> >> plans
>> >> >> for providing
>> >> >> Python binding to this?
>> >> > I can't tell if it's a good idea, but you can definitely add whatever
>> >> > you
>> >> > want to the DataSourceManager dialog with plain python:
>> >> > class ConcreteDataSourceWidget(QgsAbstractDataSourceWidget):
>> >> > pass
>> >> > class ConcreteSourceSelectProvider(QgsSourceSelectProvider):
>> >> > def providerKey(self):
>> >> > return "MyTestProviderKey"
>> >> > def text(self):
>> >> > return "MyTestProviderText"
>> >> > def icon(self):
>> >> > return QIcon()
>> >> > def createDataSourceWidget(self):
>> >> > return ConcreteDataSourceWidget()
>> >> > def ordering(self):
>> >> > return 1
>> >> > registry = QgsSourceSelectProviderRegistry()
>> >> > registry.addProvider(ConcreteSourceSelectProvider())
>> >> > Note that the DataSourceManager dialog is created when QGIS starts,
>> >> > you
>> >> > will
>> >> > want to register your provider early in the startup process, for now,
>> >> > there
>> >> > is no way to refresh the dialog after it has been constructed.
>> >> Thanks Alessandro. Is this example to add a provider type? MetaSearch
>> >> simply wants to open a given existing provider dialog, open based on a
>> >> given
>> >> provider type and let the user interact from there.
>> >> ..Tom
>> > Yes, that's the way to add a new "provider" (it does not really need to
>> > be a
>> > provider) to the items in the data source manager dialog.
>> > Maybe you wanted to use this:
>> > http://qgis.org/api/classQgsDataSourceManagerDialog.html#a6b9046d38467a13ec321a70166bff289
>> Thanks Alessandro. Is QgsDataSourceManagerDialog planned to be
>> available via Python? See:
>> http://qgis.org/api/classQgsDataSourceManagerDialog.html (docs say not
>> available in Python
>> bindings)
> Yes, that was planned. The idea was to build a generic re-usable widget to
> select data sources.
> But you are probably talking about exposing it through iface, correct?
Would that work currently/is that possible? At this point the main
goal is to fix MetaSearch [1]
in master given the changes to the data source/provider dialogs.
[1] https://github.com/qgis/QGIS/blob/master/python/plugins/MetaSearch/dialogs/maindialog.py#L754-L792
>> > Btw you can also get the individual source selects from provider
>> > registry:
>> > QgsProviderRegistry.instance().createSelectionWidget('ogr').show()
>> This is exactly what MetaSearch is doing currently which results in the
>> issues originally mentioned.
>> ..Tom
>> > Cheers.
>> >> >> Thanks
>> >> >> ..Tom
>> >> >> [1]
>> >> >> https://github.com/qgis/QGIS/blob/master/python/plugins/MetaSearch/dialogs/maindialog.py#L759-L792
>> >> >> [2]
>> >> >> https://gist.github.com/tomkralidis/dccb49efa760a585be38ee0c3188b8b3
>> >> >> [3] http://qgis.org/api/classQgsDataSourceManagerDialog.html
>> >> >> _______________________________________________
>> >> >> QGIS-Developer mailing list
>> >> >> QGIS-Developer at lists.osgeo.org
>> >> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> > Alessandro Pasotti
>> >> > w3: www.itopen.it
>> > Alessandro Pasotti
>> > w3: www.itopen.it
> Alessandro Pasotti
> w3: www.itopen.it
