[QGIS-Developer] Rendering of Icons
Robert Szczepanek
robert at szczepanek.pl
Mon Nov 13 13:32:30 PST 2017
Hi Calvin,
How to render sharp icons is described in my design guidelines
(http://robert.szczepanek.pl/gis-icons-0.1/). It depends on objects
(lines) location on grid at target resolution.
Inkscape writes in SVG many additional tags. Our goal is to decrease SVG
icon size, so final vector files are simply optimized by external tools.
regards
Robert
W dniu 13.11.2017 o 21:46, C Hamilton pisze:
> I was wondering how you turn the QGIS .svg icons into .png icons that
> are used in the tool bars. I have been using Inkscape and the resulting
> icons that I produce starting from the QGIS .svg files don't seem to be
> as sharp and clear as what is distributed with QGIS. The other thing I
> have found is that the QGIS .svg files are very small. If I read them
> into Inkscape and save them back out they are much larger.
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
