[QGIS-Developer] Deploy plugin by setting QGIS_PLUGINPATH
Zhang Qun
zhangq.rhy at gmail.com
Thu Nov 16 19:42:44 PST 2017
Hi Borys, I found your symbolic method is quite neat and useful. In this
way I could directly start QGIS even from clicking the icon in launch bar
without worrying about setting the env variables. Thanks.
Best regards,
Zhang Qun
On Fri, Nov 17, 2017 at 11:15 AM, Zhang Qun <zhangq.rhy at gmail.com> wrote:
> Hi Borys, thanks for your kind reply and your advice setting the variable
> pointing to its parent folder of the plugin worked.
> I also found I need to check the plugin manager list before my plugin can
> show in the menu. The plugin manager somehow loaded the plugin while I
> check the list.
> Thank you a million.
> Best regards,
> Zhang Qun
> On Thu, Nov 16, 2017 at 10:13 PM, Borys Jurgiel <lists at borysjurgiel.pl>
> wrote:
>> I'm sorry for the messy reply made by my wonderful kmail5 ;p
>> The first paragraph is outdated - I checked and it works. The second is an
>> alternative solution, and the direct response to your question is on the
>> end.
>> Regards,
>> Borys
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/a9e93611/attachment.html>
