[QGIS-Developer] Preview job and slow datasources
Matthias Kuhn matthias at opengis.ch
Thu Nov 16 23:10:21 PST 2017
Thanks, that's an interesting information.
What datatype are your rasters?
On 11/17/2017 03:53 AM, Patrick Dunford wrote:
> With the second command
> iface.mapCanvas().setPreviewJobsEnabled(False)
> when I run that command it drops back to 16 GB
> On 16/11/17 23:15, Matthias Kuhn wrote:
>> Hi Patrick,
>> Would be interesting to do this test with previews enabled and
>> disabled. Then we'll see if it's actually the previews or some other
>> mechanism that is causing this.
>> IIRC only a composite image is saved in the preview jobs and not each
>> layer separately, but that's just what I remember and not evidence based.
>> You can enable them in the python console with
>>     iface.mapCanvas().setPreviewJobsEnabled(True)
>> and disable with
>> Thanks for a feedback
>> Matthias
>> On 11/16/2017 08:42 AM, Patrick Dunford wrote:
>>> In my current project using Qgis 2.99, turning off the rasters uses
>>> 16 GB, turning them on uses 52 GB
>>> I do not believe it is independent from the number of layers that
>>> are being displayed.
>>> Previous versions of the software did not cache every single raster
>>> (the number of rasters actually being displayed on the canvas at any
>>> one time is a small fraction of the total number in the project)
>>> On 16/11/17 20:11, Matthias Kuhn wrote:
>>>> Hi Patrick,
>>>> This uses some memory (~ canvas width pixels * canvas height pixels
>>>> * 8 preview images * 32 bit RGBA), so let's assume 50 MB to 100 MB.
>>>> This consumption is independent from the number or type of layers.
>>>> Matthias
>>>> On 11/16/2017 08:02 AM, Patrick Dunford wrote:
>>>>> So to put it another way this is the reason why Qgis wants to use
>>>>> a huge amount of memory (40 GB) when I have a lot of raster images
>>>>> loaded in the background.
>>>>> On 16/11/17 18:56, Tim Sutton wrote:
>>>>>> Hi
>>>>>>> On 16 Nov 2017, at 04:35, Patrick Dunford
>>>>>>> <enzedrailmaps at gmail.com <mailto:enzedrailmaps at gmail.com>> wrote:
>>>>>>> What is this "preview job" function?
>>>>>> Its application logic to prefetch / pre-render offscreen content
>>>>>> in anticipation of user panning the map.
>>>>>> Regards
>>>>>> Tim
>>>>>>> _______________________________________________
>>>>>>> QGIS-Developer mailing list
>>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>>> <mailto:QGIS-Developer at lists.osgeo.org>
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> *Tim Sutton*
>>>>>> *Co-founder:* Kartoza
>>>>>> *Project chair:* QGIS.org <http://QGIS.org>
>>>>>> Visit http://kartoza.com <http://kartoza.com/> to find out about
>>>>>> open source:
>>>>>> Desktop GIS programming services
>>>>>> Geospatial web development
>>>>>> GIS Training
>>>>>> Consulting Services
>>>>>> *Skype*: timlinux
>>>>>> *IRC:* timlinux on #qgis at freenode.net <http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/911b5de4/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/911b5de4/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
