[QGIS-Developer] Qt4 Designer - custom widgets - Manjaro
Matthias Kuhn matthias at opengis.ch
Fri Nov 17 11:45:59 PST 2017
Hi Anjo,
Designer plugins need to be installed to the proper location, which
unfortunately isn't always straightforward and to my knowledge needs to
be manually configured by packagers.
The important thing is, that the libqgis_customwidgets.so file is in the
location where QtDesigner looks for it. On my computer (Fedora Linux)
this is /lib64/qt4/plugins/designer/libqgis_customwidgets.so.
I hope that helps
Matthias
On 11/16/2017 04:21 PM, Anjo Weichbrodt wrote:
> Hi everyone,
> I am trying to work with the Qgs custom-widgets in Qt4 Designer. I am
> running Manjaro on kernel 4.14.
> So far I tried to install QGIS 2.18 from the AUR compiling it with the
> option -WITH_CUSTOM_WIDGETS=TRUE.
> No custom widgets appeared after that in QT4 designer.
> Thanks for your help,
> Anjo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/5852e6e3/attachment.html>
More information about the QGIS-Developer mailing list
