[QGIS-Developer] How to call add feature attributes dialog from a plugin
Alexandre Neto senhor.neto at gmail.com
Fri Nov 17 16:10:06 PST 2017
openFeatureForm() is what you are looking for:
http://doc.qgis.org/api/2.18/classQgisInterface.html#a11b90f38afd09ac5e9f363933ee4a509
C Hamilton <adenaculture at gmail.com> escreveu no dia sexta, 17/11/2017 às
17:02:
> When a points vector layer is enabled for editing, and the "Add Feature"
> tool is selected, when you click on the map you get a popup dialog ("Points
> - Feature Attributes") that allows you to enter the vector layer attributes.
> Is it possible to programmatically access this dialog from a plugin that
> is going to add a point to the map, but would like an attribute dialog to
> pop up for entering the attributes? I would rather make use of the existing
> function and not reinvent it.
> Is there a difference between these two functions when adding a feature to
> a vector layer other than the first adds a single feature and the second
> can add multiple features?
> layer.addFeature(feature)
> layer.dataProvider().addFeatures([feature])
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171118/79b39cd4/attachment.html>
More information about the QGIS-Developer mailing list
