[QGIS-Developer] Processing "Create layer from extent" missing output
matteo
matteo.ghetta at gmail.com
Mon Nov 20 06:52:03 PST 2017
Hi devs,
I'm testing Processing in QGIS master. The algorithm "Create layer from
extent" has perfect sense when used into a model, but when used as
standalone no outputs are created.
Or better, the output pretends to be a polygon layer but nothing is
shown in the map (attribute table contains correctly 1 feature).
Is this the expected behavior or the output must be a polygon?
Thanks for any suggestion
Cheers
Matteo
