[QGIS-Developer] Refactor Fields: save and load mapping configuration
Mathieu Pellerin nirvn.asia at gmail.com
Thu Nov 23 00:16:34 PST 2017
You could potentially use a model to save refactor fields settings. That
said, there's currently a problem (see issue
https://issues.qgis.org/issues/17421) preventing this algorithm from being
used in a model.
M
On Thu, Nov 23, 2017 at 3:01 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi,
> The refactor fields algorithm is potentially very powerful.
> However, I do miss a way to save and load the configuration (or maybe I
> just haven't found it). I have layers with many fields and I am adding
> additional fields with expressions.
> Every time I run it, I have to do the configuration again and again. Is
> there a way to save and load the mapping configuration? It would save me a
> lot of time!
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171123/731ad2c4/attachment.html>
More information about the QGIS-Developer mailing list
