[QGIS-Developer] CRS for GeoJson Data
Etienne Trimaille
etienne.trimaille at gmail.com
Fri Nov 24 07:18:27 PST 2017
We are using GeoJSON on your plugin, with different projections, it works
well, no problem to read it in QGIS.
2017-11-24 15:54 GMT+01:00 C Hamilton <adenaculture at gmail.com>:
> Given that the GeoJSON standard specifies WGS84 shouldn't that be the
> default that QGIS uses when it saves a GeoJSON file? I guess there could be
> an option that would allow legacy GeoJSON files. What would it take to have
> QGIS always save WGS84 by default?
> For now I am updating Lat Lon Tools to support GeoJSON points. For my
> purposes I will stick by the standard and not worry about alternative CRS
> GeoJSON files.
> Calvin
> On Wed, Nov 22, 2017 at 5:23 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On mercredi 22 novembre 2017 15:08:08 CET Tom Chadwin wrote:
>> > I remember irritated tweets from someone like Sean Gillies involved the
>> spec
>> > about how projected CRSes had no place in GeoJSON.
>> The last year standardized version of GeoJSON, IETF RFC7946, mentions in
>> https://tools.ietf.org/html/rfc7946#page-12
>> The coordinate reference system for all GeoJSON coordinates is a
>> geographic coordinate reference system, using the World Geodetic
>> System 1984 (WGS 84) [...]
>> Note: the use of alternative coordinate reference systems was
>> specified in [GJ2008], but it has been removed from this version of
>> the specification [...]
>> Regarding OGR, it will support reading & writing GeoJSON files with any
>> CRS. Unless that on the write side you specify RFC7946=YES as layer
>> creation option, in which case automatic reprojection to WGS84 is done.
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171124/fc315202/attachment.html>
