[QGIS-Developer] php-cgi not found after installing QGIS Server on Windows
Aitor Gil Martin sigeo.agmartin at getxo.eus
Tue Nov 28 04:33:23 PST 2017
Hi René-Luc,
I have been following your excellent guide without issues. It's hard to find on internet such a detailed guide on the geeky task of installing Qgis server + lizmap.
I installed Apache and PHP  (x64 both) succesfully so far.
I wanted to install PostgreSQL + Postgis. My doubt arrives when I see in the php properties:
[cid:image001.png at 01D3684D.760117F0]
The libpq library says PostgreSQL 9.6.2(win32).
Does this mean that I need to install a x32 PostgreSQL versión and not x64?
Can I install PostgreSQL 10 version?
Can I install PostgresQL 9.6.6 (newer than 9.6.2)?
The installation before 9.6.2 I have found is postgresql (x32) 9.5.10: https://www.enterprisedb.com/download-postgresql-binaries . Is this the one it is recommended to install?
Thank you very much for you incredible work with lizmap and your help to the community.
Regards,
Aitor
De: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] En nombre de René-Luc Dhont
Enviado el: lunes, 27 de noviembre de 2017 14:14
Para: qgis-developer at lists.osgeo.org
Asunto: Re: [QGIS-Developer] php-cgi not found after installing QGIS Server on Windows
Hi Aitor,
Did you use this documentation ?
https://docs.3liz.com/en/install/windows.html#qgis-server-installation
Regards,
René-Luc
Le 27/11/2017 à 13:30, Aitor Gil Martin a écrit :
I installed QGIS Server 2.18, apache, QGIS Desktop 2.18 and all their dependencies using OSGeo4w x32 setup wizard on a Windows Server 2008 R2 SP1 x64 virtual server.
After the installation I type localhost on my chrome browser to see the Apache's landing page and I am getting the following error:
Not Found
The requested URL /cgi-bin/php-cgi.exe/index.phtml was not found on this server.
I uninstalled and installed everything several times using OSGeo4w but I keep getting the same message. Something is not properly installed or missing.
Can anyone give me a clue on what might be happening?
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171128/67d467a3/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171128/67d467a3/attachment-0001.png>
More information about the QGIS-Developer mailing list
