[QGIS-Developer] Python error in processing on 2.99 startup
Larry Shaffer larrys at dakotacarto.com
Wed Nov 29 09:40:49 PST 2017
Hi Tim,
Ran into the same thing today, but with more output on the error:
PermissionError: [Errno 13] Permission denied:
'/usr/local/opt/grass7/grass-base/etc/colors/grass'
Changing line # 108 in:
python/plugins/processing/algs/grass7/Grass7Utils.py
shell=False,
to:
shell=True if isMac() else False,
fixes the issue for me. Processing loads and GRASS algs open. (Not sure if
True is needed for other platforms; untested.)
Fix not pushed. Please verify on your setup first (mine is macOS 10.11.6).
Thanks!
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
Boundless Desktop and QGIS Support/Development
Boundless Spatial - http://boundlessgeo.com
lshaffer at boundlessgeo.com
On Wed, Nov 29, 2017 at 7:39 AM, Tim Sutton <tim at kartoza.com> wrote:
> Hi All
> Its been a few days since I pulled from master - now I am getting the
> error below on startup. Does anyone else get it? (Building on MacOS here):
> Couldn't load plugin 'processing' due to an error when calling its
> initGui() method
> Traceback (most recent call last):
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/qgis/utils.py", line 345, in startPlugin
>     plugins[packageName].initGui()
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/ProcessingPlugin.py", line 178, in initGui
>     self.toolbox = ProcessingToolbox()
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 93, in __init__
>     self.fillTree()
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 317, in fillTree
>     self.fillTreeUsingProviders()
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 382, in fillTreeUsingProviders
>     providerItem = TreeProviderItem(provider, self.algorithmTree, self)
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 513, in __init__
>     self.setToolTip(0, self.provider.longName())
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7AlgorithmProvider.py", line 122, in longName
>     version = Grass7Utils.installedVersion()
>   File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7Utils.py", line 113, in installedVersion
>     startupinfo=si if isWindows() else None
>   File "/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/subprocess.py", line 707, in __init__
>     restore_signals, start_new_session)
>   File "/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/subprocess.py", line 1333, in _execute_child
>     raise child_exception_type(errno_num, err_msg)
> Python version: 3.6.2 (default, Jul 17 2017, 16:44:45) [GCC 4.2.1
> Compatible Apple LLVM 8.1.0 (clang-802.0.42)]
> QGIS version: 2.99.0-Master Master, e8213b8e41
> Python Path:
>    - /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/
>    plugins/processing
>    - /Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/
>    default/python
>    default/python/plugins
>    - /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins
>    - /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH
>    - /usr/local/opt/gdal2-python/lib/python3.6/site-packages
>    - /usr/local/opt/python3/Frameworks/Python.framework/
>    Versions/3.6/lib/python36.zip
>    Versions/3.6/lib/python3.6/lib-dynload
>    Versions/3.6/lib/python3.6/site-packages
>    Versions/3.6/lib/python3.6/site-packages/pycharm-debug-py3k.egg
>    default/python
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171129/fefb001a/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171129/fefb001a/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
