[QGIS-Developer] Processing modeler GUI unusable in KDE / Plasma
Nyall Dawson
nyall.dawson at gmail.com
Wed Nov 29 23:09:54 PST 2017
On 30 November 2017 at 16:39, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Mathieu,
> Thanks for your efforts! I just tested it - unfortunately, your commit does
> not solve my issue.
> I also tested with a new virgin user profile to make sure there isn't some
> old setting causing the troubles.
> Custom widgets support is also not enabled.
Can you try:
- revert https://github.com/qgis/QGIS/commit/5dce8edb
- build with custom widgets enabled and installed
I want to rule out the custom widgets, and I suspect just switching
them off in the build isn't enough to clean up the remnants of them.
Nyall
