[QGIS-Developer] Does Polyline.intersects(Point) work in QGIS master?
Germán Carrillo
carrillo.german at gmail.com
Thu Nov 30 04:44:30 PST 2017
Thank you Nyall, that makes sense.
It would be nice to have a tolerance parameter so that this very little
discrepancies can also be found, but I guess one could snap one geometry to
the other (with such little distance as tolerance) and then run intersects.
Regards,
Germán
2017-11-29 17:56 GMT-05:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 29 November 2017 at 02:22, Germán Carrillo <carrillo.german at gmail.com>
> wrote:
> > Hi devs,
> > do you know why this polyline
> > >>> my_line = QgsGeometry().fromWkt('0 0, 963461.42999999970197678
> 1077875.79199999943375587, 1 1')
> > and this point
> > >>> my_point = QgsGeometry().fromWkt("Point (963461.430 1077875.792)")
> > don't intersect?
> > >>> my_line.intersects(my_point) # returns False
> Because we use the GEOS library to test intersects, and it performs an
> exact intersection test. So 963461.42999999970197678
> 1077875.79199999943375587 is not the same as 963461.430 1077875.792.
> This is the same behaviour in 2.x, and all other GEOS based projects
> (e.g. PostGIS gives the same result).
> Nyall
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
http://twitter.com/GeoTux2
http://about.me/germancarrillo
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171130/4153f5f4/attachment.html>
