[QGIS-Developer] QGIS master branch fails make install on macOS 10.12.6
Etienne Trimaille etienne.trimaille at gmail.com
Fri Oct 6 03:45:32 PDT 2017
Hi Joel,
I'm far away able to answer your problem. But I can compile perfectly using
brew with https://github.com/qgis/homebrew-qgisdev
My 2 cents,
Etienne
2017-10-06 9:46 GMT+02:00 Joel Buckley <qgis at spam.joelbuckley.com.au>:
> Hi,
> I am having some difficulty running `make install`, and compiling QGIS
> into a single standalone application on macOS. I can successfully run
> configuration and `make`, and can launch the `make`-d code from
> build/output/bin with no problem.
> `make install` runs without complaint and returns 0 (success), but when I
> try to launch the newly create QGIS.app, it immediately crashes, and
> produces a crash report (attached for brevity).
> I have googled and attempted to parse the crash log, but the errors it
> reports are beyond my capability. I'm hoping someone on the list might have
> some input on how to remedy this?
> Configuration information:
> QGIS version: current master branch
> QT5, python 3
> macOS 10.12.6
> Regards,
> Joel Buckley
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171006/a6ba94db/attachment.html>
More information about the QGIS-Developer mailing list
