[QGIS-Developer] Custom CRS broken in master?
Anita Graser anitagraser at gmx.at
Sat Oct 7 05:07:50 PDT 2017
I've now tested this on another machine and the issues are same.
I open separate tickets or one with all three issues?
Regards,
Anita
On Fri, Oct 6, 2017 at 7:46 PM, Anita Graser <anitagraser at gmx.at> wrote:
> Hi,
> I'm experiencing a couple of issues related to custom / generated CRS in
> master (tested using OSGeo4W):
> 1. In Processing: If the input layer uses a generated / custom CRS, the
> output layer is loaded in a wrong CRS. In my case, the layers were wrongly
> assigned WGS84. (Note that, in settings, I've configured that QGIS should
> "prompt for CRS" if a layer without CRS info is loaded.) --> Reported
> https://issues.qgis.org/issues/17254
> 2. I have a project with a custom CRS used as the project CRS. It was
> created with 2.14. When I open it in master, a different CRS is assigned.
> Could be the one with the same random generated ID that custom CRS get.
> 3. The Custom CRS Definition dialog is a mess. Most of the time, I cannot
> make it save the new CRS I'm trying to add. At the same time, existing
> entries are duplicated on opening & closing the dialog.
> Anyone else having these issues? Or is my local install just really broken?
> Regards
> Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171007/cb5eeb75/attachment-0001.html>
More information about the QGIS-Developer mailing list
