[QGIS-Developer] set and export FID with OGR provider
Even Rouault even.rouault at spatialys.com
Tue Oct 10 04:08:51 PDT 2017
On mardi 10 octobre 2017 12:58:36 CEST G. Allegri wrote:
> Well, you almost convinced me, but for what I can see from the ogr2ogr
> docs, if -preserve-fid is not set the output driver is expected to create
> the FIDs [1]. This means that if a a FID is not set (and not preserved) the
> GeoJSON output driver should write it.
Ah the doc of -preserve_fid is not completely accurate. In the specific case of
GeoJSON, it doesn't need to create a FID if none is provided to it, so it doesn't create
one. But for drivers like shapefile, PG, etc... the output driver needs to assign a FID to
the new feature.
I've just changed the doc to:
"Use the FID of the source features instead ofletting the output driver to
automatically assign a new one (when it needs to assign a FID. Some formats, like
GeoJSON, have optional FID)"
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171010/ff3be433/attachment.html>
More information about the QGIS-Developer mailing list
