[QGIS-Developer] MSSQL Spatial vector features not showing up in QGIS 2.18 up
Nathan Woodrow madmanwoo at gmail.com
Thu Oct 26 04:54:56 PDT 2017
You need to have a unique int based column QGIS can use as a row id at the
moment.  That might be why.
On Thu, Oct 26, 2017 at 9:40 PM, Diego Sartori <gisdsh at gmail.com> wrote:
> I'm importing a MSSQL 2008 Spatial layer in QGIS. In version 2.14 it works
> OK, I can see the vector features and interact with the associated
> attribute tables. But in versions 2.18 and 2.99, though the connection is
> OK (I can see the attribute tables), the features are not showing up in the
> map canvas. I can even modify the data in the tables but I can't
> graphically select the features for editing.
> I'm using a Windows 10 PC. The 3 versions of QGIS are runnig in the same
> machine, at the same time, with the same configuration. I've tried with the
> standalone installer and with the OSGEO4W installer (32 bit).
> ¿Anything changed from version 2.14 to newer versions that I can't get the
> features drawn on the map in version 2.18.13 and 2.99.0?
> This is my first post here and I'd like to add some screen captures, ¿how
> should I poceed?
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171026/9f8cdd7c/attachment.html>
More information about the QGIS-Developer mailing list
