[QGIS-Developer] FeatureIterator Python question
Andreas Neumann a.neumann at carto.net
Fri Sep 15 07:27:09 PDT 2017
Thanks Matthias for explaining about that. Good to know.
Andreas
On 15.09.2017 16:22, Matthias Kuhn wrote:
> Hi Andreas,
> that will be done automatically when the iterator scopes out or the last
> feature is yielded.
> There is normally no reason to care about this method.
> Matthias
> On 09/15/2017 04:04 PM, Andreas Neumann wrote:
>> Just a quick followup question.
>> I see that the QgsFeatureIterator has a close method.
>> Should Python authors care about closing an existing feature iterator or
>> would this be automatically done when the script stops executing?
>> Andreas
>> On 15.09.2017 15:48, Andreas Neumann wrote:
>>> Hi Matteo and Matthias,
>>> Thanks - that works fine. I did not know that this changed in Python 3.
>>> All the poor QGIS book authors who need to rewrite their books ...
>>> about this Python changes.
>>> Helps a lot!
>>> Andreas
>>> On 15.09.2017 15:44, matteo wrote:
>>>> Hi Andreas,
>>>> if I'm not wrong the next method is not been removed, it is a python
>>>> 3 *fix*
>>>> https://stackoverflow.com/questions/1073396/is-generator-next-visible-in-python-3-0
>>>> so instead of:
>>>> it = layer.getFeatures()
>>>> it.next()
>>>> just type
>>>> next(it)
>>>> Matteo
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
