[QGIS-Developer] Label Text Type case option 'Capitatlize first letter' ONLY capitalizes first letter
Richard Duivenvoorde rdmailings at duif.net
Fri Sep 22 03:20:20 PDT 2017
On 22-09-17 11:29, Tom Chadwin wrote:
> Hi Richard
> If you are raising this for yourself, I'm sure you know this, but you can
> achieve what you need with the expressions function "title()". I can also
> see occasions when first-letter could be of use.
> If your point is for other users, then there is certainly an argument for
> including title case in that formatting dropdown.
Hi Tom,
I did not know of this type (title-case?) of capitalization... googleing
for it, I found:
http://wiki.c2.com/?CapitalizationRules
ough.. a LOT of different rules/names... and Camelcase is actually NOT
what I think it was...
Which brings me to:
- should we not bring all these capitalization options to expressions
and then
- should we not either remove the 'Type case' drop down from the label
dialog? As the use of expression is (then) much stronger.
In that way you do not have to maintain this capitalisation stuff in 2
places.
OR do expressions and the labeling dropdown use different execution
path's so the dropdown is just faster (which is important for labeling!)?
Regards,
Richard
More information about the QGIS-Developer mailing list
