[QGIS-Developer] Custom widgets and Qt Designer 4 and 5
Etienne Trimaille etienne.trimaille at gmail.com
Tue Apr 3 11:25:03 PDT 2018
Hi Matteo,
I'm finally trying to use custom widgets from QT Creator instead of using
promoted widgets.
I'm facing the same issue with the generated path. It's not using
"qgis.gui" so it's failing during the import in QGIS.
Did you fix this issue?
I can manually fix these imports, but I'm asking if there is a fix for
that. Thanks
2018-03-20 14:33 GMT+01:00 matteo <matteo.ghetta at gmail.com>:
> Hi Matthias,
> >> * not being able to see the QGS widgets in QT Designer 5 is related with
> >> GDAL version, isn't it? If copying in the
> >> /usr/...../pyqt5/plugin/designer the libqgiscustomwidget not compiled
> >> against gdal >= 2.20 won't work
> > That's what I was talking about. It doesn't matter which gdal version
> > you link against.
> ok so technically one I have the file libqgiscustomwidget.so and I've
> copied it into the folder I can even clean the directory of QGIS
> (compiled against gdal 2.20)?
> Thanks for the patience ;)
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180403/c53a1c16/attachment.html>
More information about the QGIS-Developer mailing list
