[QGIS-Developer] Problem with 3D during compilation in debian sid
Martin Dobias wonder.sk at gmail.com
Tue Apr 10 05:24:23 PDT 2018
Hi Matteo
do you have qt3d5-dev package installed? That's the package containing
#include files and those extra .cmake files...
Cheers
Martin
On Tue, Apr 10, 2018 at 2:18 PM, matteo <matteo.ghetta at gmail.com> wrote:
> Hi guys,
> sorry sorry to bother the list you again with this, but I'm stack and
> maybe someone has a quick solution.
> I have a really fresh installation of debian unstable, so all the Qt
> dependencies should be satisfied for the 3D.
> However, if I enable the WITH3D flag in ccmake I'm not able to configure
> it even if I have all the libqt5 installed (also libqt53dextras).
> If someone has a solution or some suggestions for this it would be
> really great
> Thanks to all
> Matteo
>   CMake Error at
> /usr/lib/x86_64-linux-gnu/cmake/Qt53DExtras/Qt53DExtrasConfig.cmake:27
> (message):
>    The imported target "Qt5::3DExtras" references the file
>       "/usr/include/x86_64-linux-gnu/qt5/Qt3DExtras"
>    but this file does not exist.  Possible reasons include:
>    * The file was deleted, renamed, or moved to another location.
>    * An install or uninstall procedure did not complete successfully.
>    * The installation package was faulty and contained
>       "/usr/lib/x86_64-linux-gnu/cmake/Qt53DExtras/Qt53DExtrasConfig.cmake"
>    but not all the files it references.
>  Call Stack (most recent call first):
> /usr/lib/x86_64-linux-gnu/cmake/Qt53DExtras/Qt53DExtrasConfig.cmake:63
> (_qt5_3DExtras_check_file_exists)
>    CMakeLists.txt:310 (FIND_PACKAGE)
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
