[QGIS-Developer] [Qgis-developer] GRASS plugin missing from Q3?
Richard Duivenvoorde rdmailings at duif.net
Thu Apr 12 02:31:05 PDT 2018
On 12-04-18 11:20, Jürgen E. Fischer wrote:
> Hi Paolo,
> On Wed, 08. Feb 2017 at 11:36:18 +0100, Paolo Cavallini wrote:
>> I just compiled from source on Debian Sid. cmake finds grass 7,
>> apparently compile runs fine, but the grass plugin is not available.
>> Does anyone confirm?
> Anyone without the GRASS library path in LD_LIBRARY_PATH or ld.so.conf should
> be able to confirm (see debian/qgis.sh.in)
Uh, yes confirmed :-)
Without:
export LD_LIBRARY_PATH=/usr/lib/grass74/lib/:<yourinstall>
You will not even SEE the grass plugin in the plugin list.
WITH the right path in your LD_LIBRARY_PATH you will see it (with me
here in sid is is: /usr/lib/grass74/lib/ )
More information about the QGIS-Developer mailing list
