[QGIS-Developer] Legend layer customization missing
Régis Haubourg regis.haubourg at gmail.com
Sat Apr 21 07:45:59 PDT 2018
Hi, I just tested forcing the layer groups to bold using advanced settings,
but it doesn't apply. Someone confirms?
Regards
Régis
Le sam. 21 avr. 2018 à 11:10, matteo <matteo.ghetta at gmail.com> a écrit :
> HI Nyall,
> > This option was dropped. The rationale was that we cannot have options
> > for every user interface setting like this or the interface becomes
> > just a daunting mess! Either bold names is good, and they should be
> > used in all installs, or they aren't needed.
> >> , capitalize...)
> > This is a bit controversial - during 3.0 development the setting was
> > made default for a while, and the option dropped. But there was
> > push-back after this and the on-by-default change was reverted, and
> > the setting was moved to the advanced settings page only.
> I perfectly understand the need to avoid every user case options..
> still wondering if this options can be added only in the advanced
> settings dialog (so there it should not result in a messed up UI). But
> as said, I don't know if this can bring to coding issues.
> Thanks for the clarification!
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180421/135db506/attachment.html>
More information about the QGIS-Developer mailing list
