[QGIS-Developer] [Qgis-user] CAD and QGIS - Working with archaeological sites
Alexandre Neto senhor.neto at gmail.com
Thu Aug 9 15:00:36 PDT 2018
On Thu, Aug 9, 2018, 22:27 C Hamilton <adenaculture at gmail.com> wrote:
> Also is there a way a non georegistered image be imported, make it
> somewhat transparent, and then interactively drag and resize it on the map
> somewhat like Google Earth? When you don't really have anything to
> reference the image to you can't use georeferencer.
I guess you could do that on layout mode. Adding an imagem, set some
transparency and then try to fit it somewhere.
Once it's on the right spot. Save the layout as image storing a world file.
Then you can add it back, and use georeferencer on the original image.
I am not a CAD guy, so I would trace it using QGIS.
Hope it helps,
Alexandre Neto
> Thanks,
> Calvin Hamilton
> Qgis-user mailing list
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180809/7a72bb9a/attachment.html>
More information about the QGIS-Developer mailing list
