[QGIS-Developer] Whatever is wrong with QGIS 3.x SQL server driver
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Dec 6 06:13:07 PST 2018
Hi Nyall - Back again ..
The 3 different sql queries from QGIS.....
-- QGIS 3, native driver
SELECT [cell100_key],[geom_flade] FROM [dbo].[cells3] WHERE
[geom_flade].STIsValid() = 1 AND
[geom_flade].Filter([geometry]::STGeomFromText('POLYGON((823546.46544876880943775
6100000, 936453.53455123119056225 6100000, 936453.53455123119056225
6150000, 823546.46544876880943775 6150000, 823546.46544876880943775
6100000))',25832)) = 1
-- QGIS 3 OGR driver
select [cell100_key], [geom_flade] from [dbo].[cells3] where
[geom_flade].STIntersects(geometry::STGeomFromText('POLYGON((823546.465448769
6100000,936453.534551231 6100000,936453.534551231 6150000,823546.465448769
6150000,823546.465448769 6100000))',25832)) = 1
-- QGIS 2, native driver
SELECT [cell100_key],[geom_flade] FROM [dbo].[cells3] where
[geom_flade].Filter([geometry]::STGeomFromText('POLYGON((826739.13043478259351104
6100000, 933260.86956521740648896 6100000, 933260.86956521740648896
6150000, 826739.13043478259351104 6150000, 826739.13043478259351104
There is not much difference in the SQL Server execution times for the 3
queries (around 200 - 300  ms) , so that can't explain the time difference
in QGIS
QGIS 2 with native driver and QGIS 3 with ogr driver uses appr. the same
time showing the map.
QGIS 3 with native driver uses appr. twice the time to show the results on
the map.
Den tor. 6. dec. 2018 kl. 11.54 skrev Nyall Dawson <nyall.dawson at gmail.com>:
> On Thu, 6 Dec 2018 at 20:34, Bo Victor Thomsen
> <bo.victor.thomsen at gmail.com> wrote:
> > Hi Nyall -
> > I'm running QGIS 3.4.2 on Windows ver.10.
> > Have there been any other changes to the SQLServer driver besides the
> validity check? (I remember vaguely something about the internal
> representation of spatial objects in the driver)
> No, nothing that would explain this. Just minor bug fixing and the port to
> Qt 5.
> I wonder if you could log the queries coming from QGIS and see if you
> can identify any changes from 2.18?
> Nyall
> > I'm asking, because I've done this type of testing QGIS 2.x before where
> the time difference between Postgres and SQL Server was relatively small
> when doing simple MBR based searches - somewhere in the vicinity of 20%
> > I would happily ditch MS SQLServer forever for spatial work and mainly
> use Postgres. However, my customers have a different opinion :-(
> > Den tor. 6. dec. 2018 kl. 11.17 skrev Nyall Dawson <
> >> On Thu, 6 Dec 2018 at 20:05, Bo Victor Thomsen
> >> > I've tried switching the validity check off as described. As far as I
> can measure, there is no time difference with or without the validity
> check. When does the validity check kick in? Writing or reading the
> features? Or both?
> >> It's on read. Writing always uses a make valid call for SQL Server to
> >> try to avoid triggering the issue.
> >> > And the validity check doesn't explain the obvious time difference
> between the OGR driver and the native QGIS driver for SQL Server
> >> Well, it would if OGR wasn't doing this check by default. What
> >> platform are you connecting from? Windows or Linux?
> >> > However, I will use your explanation about SQL Server's behavior
> regarding invalid geometries as an argument for my customers to switch to
> Postgres instead of using SQLServer :-)
> >> There's also these points: https://www.pg-versus-ms.com/ (I think I
> >> could write as much again on the spatial side of things alone.) If you
> >> have a choice, Postgres is far superior in so many ways.
> >> Nyall
> >> > Den tor. 6. dec. 2018 kl. 10.17 skrev Nyall Dawson <
> >> >> On Thu, 6 Dec 2018 at 19:05, Bo Victor Thomsen
> >> >> > Hi list -
> >> >> > I've done some experiments with a dataset consisting of 440000
> rows and uploaded this to two database servers: Postgres and SQLServer.
> Both tables has indexes on Primary key and the spatial column.
> >> >> > And then connected to both tables in QGIS. The SQL server is 3
> times slower in retrieving the dataset than Postgres in QGIS!
> >> >> It's probably the extra validity checks which were added. SQL Server
> >> >> itself is broken by design when it comes to spatial data handling and
> >> >> if it encounters an invalid geometry it will silently abort the
> >> >> request and you'll be missing features from the layer. But there's
> *no
> >> >> way* for QGIS to detect when this occurs! Accordingly QGIS takes the
> >> >> "safer is better" approach and forces a validity check and make valid
> >> >> step as part of the queries sent to SQL Server. This avoids the
> >> >> potentially missing features, but comes at a large cost.
> >> >> If you're 100% sure that your tables have no invalid geometries (and
> >> >> never will have any!), you *can* switch this check off. But be
> >> >> warned... if you ever introduce invalid geometries into your tables,
> >> >> you'll get data loss. The setting is under the SQL Server
> connection's
> >> >> properties -- "skip invalid geometry handling".
> >> >> Let me know if this helps at all
> >> >> Nyall
> >> > Med venlig hilsen
> >> > Bo Victor Thomsen
> > Med venlig hilsen
> > Bo Victor Thomsen
Med venlig hilsen
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181206/1529b13a/attachment-0001.html>
More information about the QGIS-Developer mailing list
