[QGIS-Developer] Keeping OTB algorithm in qgis processing
Alexander Bruy alexander.bruy at gmail.com
Thu Feb 1 02:16:49 PST 2018
Hi Werner,
code already here:
 - grass https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/grass7
 - saga https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/saga
Only small updates are needed to turn it into plugins. I can turn them
into plugins and
publish if there is an agreement about this approach. Then I will be
happy to transfer
ownership to any interested person.
Some documentation about adding new algorithms to GRASS provider can be found
in https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/grass7.txt,
but it is slightly outdated. Same approach used for SAGA.
2018-02-01 12:07 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> Hi Alex,
> Thats exactly what I meant.
> I know that (currently) there are no plugin for SAGA and GRASS but if I
> understood everything correctly the point is to create such plugins.
> My Question was more or less if there is already code existing for it or if
> we have to wait until they are removed before the plugins can appear - but
> this is now answered.
> Waiting for the plugins ;)
> And hopefully good documentation howto bring new algorithms alive..
> thanks and kind regards
> Werner
> On Thu, Feb 1, 2018 at 11:00 AM, Alexander Bruy <alexander.bruy at gmail.com>
> wrote:
>> Hi Werner,
>> there are no plugins for SAGA and GRASS, but this is just because they
>> are in core.
>> Also seems we need to clarify, removal from core does not means wiping
>> all stuff,
>> this just mean that existing code will be separated into plugin and
>> published on GitHub
>> and QGIS plugins repository. Then interested people can take ownership
>> and continue
>> development and maintenance.
>> Exactly in the same way we removed LiDAR tools provider (now
>> maintained by Martin Isenburg)
>> and TauDEM provider (maintained by me, along with several others
>> Processing providers).
>> 2018-02-01 10:39 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
>> > Hi all,
>> > I am also in favour of removing all the work that is not directly
>> > related to
>> > QGIS.
>> > But I'd also like to ask if there is already a plugin available (on
>> > github?)
>> > that for e.g. readds the GRASS functionality?
>> > Furthermore I'd like to know if it is possible to create a plugin for
>> > official stable GRASS and GRASS development version, which in the best
>> > case
>> > can be installed side by side?
>> > (Same applies to SAGA and all the other providers).
>> > I am sure there is a huge possibility that an ecosystem will be created
>> > around those kind of plugins.
>> > kind regards
>> > Werner
>> > On Thu, Feb 1, 2018 at 9:33 AM, G. Allegri <giohappy at gmail.com> wrote:
>> >> +1 also from me to the removal of the providers from core. IMHO I would
>> >> also remove GRASS, but I understand it could be a tough decision.
>> >> The provider system + plugin architecture provide all the means to keep
>> >> them separate from the core.
>> >> We all agree, I guess, that less is better then more, to guarantee the
>> >> highest quality we can afford.
>> >> Giovanni
>> >> Il 1 feb 2018 09:23, "Paolo Cavallini" <cavallini at faunalia.it> ha
>> >> scritto:
>> >>> Hi Rashad,
>> >>> Il 31/01/2018 10:43, Rashad Kanavath ha scritto:
>> >>> > What I can propose is to lower the burden on maintenance but the
>> >>> > code
>> >>> > should be put back to qgis if possible.
>> >>> > So qgis can focus on issue related only to that and after a while
>> >>> > things
>> >>> > will stabilize.
>> >>> > Indeed, if there is something broken in this algo otb team will help
>> >>> > fix it.
>> >>> thanks for your offer, much appreciated. Would this include also the
>> >>> inclusion of OTB in the standalone installers for Windows? It would be
>> >>> good to make sure we always have the most appropriate version, both
>> >>> for
>> >>> 32 and 64 bit.
>> >>> All the best.
>> >>> Paolo Cavallini - www.faunalia.eu
>> >>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> >>> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
>> >>> _______________________________________________
>> >>> QGIS-Developer mailing list
>> >>> QGIS-Developer at lists.osgeo.org
>> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexander Bruy
Alexander Bruy
More information about the QGIS-Developer mailing list
