[QGIS-Developer] QGIS GeoPackage saving issues
Richard Duivenvoorde rdmailings at duif.net
Fri Feb 2 07:14:43 PST 2018
Hi Devs,
Looking at a gpkg problem I created an issue for some time ago:
https://issues.qgis.org/issues/17899
It appears that QGIS is doing some guessing about the primary key?
Like, IF there is a fid, it is used as PK, but gpkg creation fails when
the original fid is not an integer.
Second: when you (in the QGIS save dialog) empty the 'fid' field (as in
this case, remove fid in the field), creation succeeds, but you end up
with a table in the gpkg with a column with an empty column name ('').
Can others confirm?
Or is this a GDAL issue?
Regards,
More information about the QGIS-Developer mailing list
