[QGIS-Developer] [Server] Is QGIS Server 3 fast yet ? the 2018-02-06
Yves Jacolin yjacolin at free.fr
Fri Feb 9 05:54:10 PST 2018
Hello all,
Thanks René-Luc for this first analysis and all other for your though.
Here some informations :)
First I won't be at Madeira and this is the 2nd hackfest I missed in one
year. That's a pity but I have a onsite trip for a customer each French
holiday.
But, I think Camptocamp has some R&D on QGIS performance so I will check
this afternoon's meeting how we can start this. Performance improvement
could be either analyze QGIS, add new test (GetFeatureInfo, etc.).
René-Luc, could you open a ticket (if not already did) about any changes
you think valuable?!
Y.
Le 08/02/2018 à 19:41, René-Luc Dhont a écrit :
> Hi Régis
> Le 08/02/2018 à 17:12, Régis Haubourg a écrit :
>> Hi René Luc,
>> thanks a lot for starting that analysis!
>> Do you plan to be in Madeira? Elaborating a complete test suite
>> together would be perfectly fitted for that task .
> I could not be in Madeira. But we can discuss about perf test suite.
>> Some questions:
>> - Trust option is only there to not query datasource when this one
>> has no metadata for PK and extent. So it should only make sense to
>> compare the first getcapabilities or project load with and without
>> trust option. Other following requests should not have any impact, so
>> we need to make sure the platform is not measuring something else in
>> the differences you note. So I don't see what you mean by
>> "completing" the trust option. Can you be more explicit ?
> Trust option can be usefull with Apache. When you use QGIS Server with
> Apache, the QGIS Server processes are regularly reset. So the QGIS
> Server cache is regularly cleaned, and the project is regularly
> reloaded. So the trust option can affect all the request not only
> GetCapabilities.
> So the average time request is affected by trust option, but I was
> thinking that this option make QGIS Server 3 faster at all scale and
> it's not the case for high scale.
> I have open an issue to request min,max, median requests time to have
> an idea of the time needed to load project.
>> - Is the test  platform requesting wms layer groups, and did you test
>> the multithread rendering? How many cores? How many cores really
>> available when testing?
> The platform requesting layers, not layer groups and multithreading
> rendering has been activated. the environnment variables are:
>     QGIS_SERVER_PARALLEL_RENDERING: "true"
>    QGIS_SERVER_MAX_THREADS: 8
>> I think we should first elaborate a common reference test suite and
>> couple a system monitoring at the same time to be sure we don't have
>> external noise in the tests, and find system bottlenecks. Then only
>> we can consider some conclusions over development priorities I think.
> The platform provided by camptomcamp is a good start and some
> enhancement has been already opened :
> * test GetCapabilties
> * test GetFeatureInfo
> * test with labels
> And we have multi options to test:
> * with and without multithreading
> * with and without local simplification (for postgres)
> * with and without data projection (here form EPSG:4326 to EPSG:3857)
> And we have other server configuration to test
> * Nginx/Supervisor
> * Embedding QGIS Server in Tornado or other Python server
>> Many thanks !
>> Régis
> Regards,
> René-Luc
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://yjacolin.gloobe.org
More information about the QGIS-Developer mailing list
