[QGIS-Developer] QGIS 3 itemById should return subclassed item
Chris Crook ccrook at linz.govt.nz
Mon Feb 12 15:28:21 PST 2018
Hi Nyall
Thanks so much for the pointer (idea that is, not C++ pointer) .. I'll give it a go
Cheers
Chris
________________________________________
From: QGIS-Developer [qgis-developer-bounces at lists.osgeo.org] on behalf of Nyall Dawson [nyall.dawson at gmail.com]
Sent: 13 February 2018 10:36
To: SIGéal
Cc: qgis-developer
Subject: Re: [QGIS-Developer] QGIS 3 itemById should return subclassed item
On 13 February 2018 at 05:51, SIGéal <sigeal at sigeal.com> wrote:
> Hi,
> This code used to work in QGIS 2.x.
> lblTitle = myComposition.getComposerItemById('title')
> lblTitle.setText('New Title')
> However, in QGIS 2.99, myLayout.itemById('title') returns this error :
> 'QgsLayoutItem' object has no attribute 'setText'
See discussion at
http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-QgsLayout-itemById-returns-wrong-object-td5350947.html
Nyall
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the QGIS-Developer mailing list
