[QGIS-Developer] PyQgis QgsCoordinateTransform constructor?
Denis Rouzaud denis.rouzaud at gmail.com
Tue Jan 9 04:26:15 PST 2018
Hi Tom,
Sadly, the build of the container you're using has been turned of for 2
months, hence it does not had the datum changes.
This was due to docker cloud failing at building QGIS at every commit.
I just manually triggered a build, let's see what comes out.
We still have to find a proper approach for this.
Denis
Le mar. 9 janv. 2018 à 08:13, Tom Chadwin <tom.chadwin at nnpa.org.uk> a
écrit :
> Thanks, Denis. That is what I am using:
> https://github.com/tomchadwin/qgis2web/blob/master/qgis2web/olwriter.py#L271
> It works locally with the OSGeo4W nightly, but it fails in Travis:
> https://travis-ci.org/tomchadwin/qgis2web/jobs/326777382#L1129
> I don't yet understand what is causing this mismatch in behaviour.
> Thanks
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180109/5dda6bc3/attachment.html>
More information about the QGIS-Developer mailing list
