[QGIS-Developer] PyQgis QgsCoordinateTransform constructor?
Denis Rouzaud denis.rouzaud at gmail.com
Tue Jan 9 04:37:15 PST 2018
Actually, I did a trick to trigger a build once a day. But the issue is
that the cloud cannot compile in less than 4 hours and the build is
canceled.
We'll have to find another solution to build the image!
Or find a way to export and reload ccache on docker cloud.
Le mar. 9 janv. 2018 à 08:26, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi Tom,
> Sadly, the build of the container you're using has been turned of for 2
> months, hence it does not had the datum changes.
> This was due to docker cloud failing at building QGIS at every commit.
> I just manually triggered a build, let's see what comes out.
> We still have to find a proper approach for this.
> Denis
> Le mar. 9 janv. 2018 à 08:13, Tom Chadwin <tom.chadwin at nnpa.org.uk> a
> écrit :
>> Thanks, Denis. That is what I am using:
>> https://github.com/tomchadwin/qgis2web/blob/master/qgis2web/olwriter.py#L271
>> It works locally with the OSGeo4W nightly, but it fails in Travis:
>> https://travis-ci.org/tomchadwin/qgis2web/jobs/326777382#L1129
>> I don't yet understand what is causing this mismatch in behaviour.
>> Thanks
>> Tom
>> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180109/773df170/attachment.html>
More information about the QGIS-Developer mailing list
