[QGIS-Developer] set unspecified precision -1 on double in spatiaLite and org providers
Matthias Kuhn matthias at opengis.ch
Fri Jan 12 02:04:43 PST 2018
Hi Dave,
the proposal is that
QgsFields::precision() always returns -1 for doubles, correct?
Sounds fine to me, 0 might be a real value (0 digits after the decimal
point) while -1 clearly indicates an arbitrary precision (as in double).
Matthias
On 01/09/2018 03:34 PM, David Signer wrote:
> Hi all
> We found different behaviors in qgsorgprovider and
> qgsspatialiteprovider regarding the field with the type double.
> In `QgsSpatiaLiteProvider::convertField` it's set to -1 when it's 0 :
> https://github.com/qgis/QGIS/blob/master/src/providers/spatialite/qgsspatialiteprovider.cpp#L82-L88
> That's why I decided to change it in
> `QgsSpatiaLiteProvider::loadFieldsAbstractInterface` as well. The
> advantage would be, that we could recognize a field with type double
> when the precision is not zero.
> But when I checked qgsorgprovider, in `QgsOgrProvider::convertField`
> the precision is not set (stays what it is) in case of double:
> https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrprovider.cpp#L143-L145
> I wonder why it's different and I ask you, if you mind, when we just
> set the precision in any case to -1 when it's a double value and it's
> not specified (means 0)?
> ThanksĀ
> Dave
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180112/2d12257e/attachment.html>
More information about the QGIS-Developer mailing list
