[QGIS-Developer] Python question: QgsVectorLayer object has no attribute 'pendingFields'
Andreas Neumann a.neumann at carto.net
Mon Jan 15 09:18:09 PST 2018
oh - thanks, Etienne and Alessandro. If this change is that recent, than
it explains why the API doc and the API break document doesn't mention
it: https://qgis.org/api/api_break.html
But - aren't we in hard freeze (no more API changes) now since a few
days already?
Being confused ....
Andreas
On 2018-01-15 18:14, Etienne Trimaille wrote:
> pendingFields is gone this morning: https://github.com/qgis/QGIS/pull/6050
> Maybe just use `fields()` ?
> 2018-01-15 20:10 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I am trying to fix some Python code that worked before, but not anymore due to API changes in master meanwhile.
>> I am getting a reference to a layer by name and then want to query the 'pendingFields'. Here is the code I use:
>> LayerParcels= QgsProject.instance().layerStore().mapLayersByName('Parcels')[0]
>> newParcel = QgsFeature()
>> newParcel .setFields(LayerParcels.pendingFields())
>> The first two lines seem to work, but the third line triggers an error:
>> AttributeError: 'QgsVectorLayer' object has no attribute 'pendingFields'
>> Why is that?
>> This code worked a few weeks before and the 'pendingFields' - according to https://qgis.org/api/classQgsVectorLayer.html [1] still exists?
>> What is wrong with my code?
>> Thanks for any hints!
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
Links:
[1] https://qgis.org/api/classQgsVectorLayer.html
[2] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/296cb629/attachment.html>
More information about the QGIS-Developer mailing list
