[QGIS-Developer] Python question: QgsVectorLayer object has no attribute 'pendingFields'
Etienne Trimaille etienne.trimaille at gmail.com
Mon Jan 15 09:20:07 PST 2018
While I'm porting my plugin, I'm usually opening this doc
https://github.com/qgis/QGIS/blob/master/doc/api_break.dox
Then I search for every new exception I have, I often find a solution there.
2018-01-15 20:14 GMT+03:00 Etienne Trimaille <etienne.trimaille at gmail.com>:
> pendingFields is gone this morning: https://github.com/qgis/QGIS/pull/6050
> Maybe just use `fields()` ?
> 2018-01-15 20:10 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I am trying to fix some Python code that worked before, but not anymore
>> due to API changes in master meanwhile.
>> I am getting a reference to a layer by name and then want to query the
>> 'pendingFields'. Here is the code I use:
>> LayerParcels= QgsProject.instance().layerSto
>> re().mapLayersByName('Parcels')[0]
>> newParcel = QgsFeature()
>> newParcel .setFields(LayerParcels.pendingFields())
>> The first two lines seem to work, but the third line triggers an error:
>> AttributeError: 'QgsVectorLayer' object has no attribute 'pendingFields'
>> Why is that?
>> This code worked a few weeks before and the 'pendingFields' - according
>> to https://qgis.org/api/classQgsVectorLayer.html still exists?
>> What is wrong with my code?
>> Thanks for any hints!
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/acabdd6c/attachment.html>
More information about the QGIS-Developer mailing list
