[QGIS-Developer] Translation state of master
Werner Macho werner.macho at gmail.com
Mon Jan 15 10:14:09 PST 2018
Hi Andreas,
I am not sure if you first need to setup your .transifexrc but the script
to pull the translations is in
./scripts/pull_ts.sh
Usually - if everything is setup correctly you can just call the script
like above.
regards
Werner
On Mon, Jan 15, 2018 at 6:49 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi Werner,
> Thanks for your reply.
> Yes, it is self-compiled.
> That would explain it. I wasn't aware that git pull of master repo does
> not fetch current translations. How do I get them? Is there a docu
> somewhere?
> Sorry for the fuss then ... so many things to learn!
> Andreas
> On 2018-01-15 18:40, Werner Macho wrote:
> Hi Andreas,
> Could you give an example of what it not translated to german?
> Because according to transifex master is translated 100%.
> Is it a self compiled QGIS and you did not pull the translations from
> transifex in?
> Is it an old master compilation with old translations?
> Probably it is even a test-master without the newest translations pulled
> in.
> I think Jürgen can tell when exactly the translations get pulled in for
> the release.
> regards
> Werner
> On Mon, Jan 15, 2018 at 2:48 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> Every once in a while I change from the english language (my personal
>> favourite) to german language, because some of my users prefer the german
>> interface and I need to explain the german terms. Switching the master
>> version to german I was a bit surprised to see a lot of english terms in
>> the german UI. Is translation something that will happen now, meaning in
>> the time between feature freeze and release?
>> Should I assist in the german translation process or is someone already
>> working on it?
>> Yet another reason not to release too soon, I think ...
>> Thanks and greetings,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/303fa0ca/attachment.html>
More information about the QGIS-Developer mailing list
