[QGIS-Developer] Eclipse config for QGIS API
Anita Graser anitagraser at gmx.at
Sat Jan 20 05:29:30 PST 2018
My Eclipse setup for Python 2 is working but trying to add a Python 3
interpreter there are new issues.
On Mon, Jan 15, 2018 at 10:18 PM, Lauri Kajan <lauri.kajan at gmail.com> wrote:
> My eclipse starter bat look like this:
> @echo off
> set OSGEO4W_ROOT=C:\OSGeo4W64
> call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
​If I keep this call to o4w_env.bat in the starter, Eclipse fails to start.
I have always used python.exe found from C:\OSGeo4W64\apps\Python36\python.exe
> as a pydev interpreter. Don't know if that matters.
When trying to add this interpreter in PyDev, I run into the following
issue:
No output was in the standard output when
trying to create the interpreter info for:
The error output contains:>><<
​Is it possible to configure Eclipse to have both a Python 2 and Python 3
interpreter?
Regards,
Anita​
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180120/4e842dab/attachment.html>
More information about the QGIS-Developer mailing list
